My 2000 Fatboy died on me, check lamp not lighting up, motor cranks over but will not run.
Discovered the Assy Fuse blown, traced problem back to Indicator Module.
I have disconnected all the harness plugin connectors on the bike, just the three wires to ignition switch connected, everything else disconnected but fuse still blowing!
I've checked the downstream side of the wiring from the module and find no wires going to ground.
I'm trying to figure out if a faulty Indicator Module can result in the Check Lamp not lighting up, the the motor not to fire up and the fuse blowing each time I turn on the ignition?
Any help would be appreciated.
