1 - 3 of 3 Posts
On the loose
Looking for info on rear brake pads for a FXSTD Deuce ? The SM says they have a slot cut in the pad and to check parts catalog for specific replacement parts.
The PM has a separate part # thats different from all the other softails. J&P seems to have the common (except FXSTD ) for all there after market rear pads.
Guess I'm looking for aftermarket pads that work since HD thinks there's are worth alot.
On the loose
Discussion Starter #2
I found out that if I use the FXSTD part # the dealer tells me that that # is superseded by the other part # for all the other softails , what a PIA for nothing , anyway all you fellow FXSTD owners your pads that you use on the front also work on the rear like the rest of the softails.
1 - 3 of 3 Posts
