1 - 6 of 6 Posts
So I was riding yesterday and I noticed my speedometer and the rest of my gauges reset to zero while I was riding going about 60. The speedometer dropped down fast sort of looked like when you pull in your clutch and the tachometer goes down.
Has anyone else experienced that problem?
If so what is it and is it an easy fix.
Thanks!
Someone posted a similar problem, was a loose connection on ignition switch.
Thanks!
I had that problem on a ultra once. It was some pins being bad in the plug form the motor to main harness . Replace I think 4 pins, fixed it right up . :)
1 - 6 of 6 Posts
