1 - 4 of 4 Posts
I'm going to install a Ness stage 1 filter on my 09 Heritage tomorrow. I want to leave the filter exposed and get rid of that football. My question is will a Harley air cleaner cover fit on a Ness stage 1 filter. All my covers have the Willie G skull and want to get the same for this. Thanks.
Hard Member
After a year of owning my Ultra, I removed the football to check and clean my filter. That's how I found out the previous owner installed an Arlen Ness Big Sucker. Now, if the filter you are using has a bolt hole in the center of the filter you can use the football screw. HD does have the skull cover plate (the same one I have). Makes the filter look awsome!
And I believe all the Ness filters have a center hole.
Discussion Starter #4
Thats the one bro. It worked good. The bracket had to be spaced out with a couple washers, but it looks good. Getting it remapped tomorrow. I know I should just go with a fuel control system, and I will when I do cams next year, but after the download, its done for this season.
1 - 4 of 4 Posts
