1 - 1 of 1 Posts
I have an 06 dyna low rider.
793503
OK I have a quick question about 180mm rear hub assembly. I sheared all 5 belt sprocket bolts off in the hub. I have an 180mm hub as u can guess but also have custom rims and the hub came with the rims. Here's the question can I just order another 180mm hub assembly from anywhere or does it have to be from the same custom wheel manufacturer cause I forgot where I got the rims from and that means if I have to get new rims that a hub chunk of change when the 180mm rear hub hit it only 300 bucks. Any advise is welcome
1 - 1 of 1 Posts
