1 - 6 of 6 Posts
While riding to woork this morning , the bike just died ...
pulled over to the side of the road
Sat there 10 minutes and then i was able to set it started ... ran 1-2 minutes and red light came on right side of speedometer then died once more..
Cecking the bike over I found that turning the key to the igination position the nothing happens
set key to the assessary position the clock displays
Showing any codes by chance?
Killer of Souls
Negative battery connection...loose
Loose negative cable. You need to follow the book procedure for replacing the battery in a 2007 Sportster.
The negative cable gets attached and tightened to the battery terminal before installing the battery. The negative cable then gets re-attached at the top of the trans.
Always connect the negative cable last, after the positive is connected.
Discussion Starter #6
removed battery and reinstalled
tightened all connections
back to normal
Thanks for all the assistance
1 - 6 of 6 Posts
