1 - 6 of 6 Posts
Hello everyone so I’m working on putting together my build and got to the point where I’m installing the starter and clutch assembly etc.
I got a jack shaft assembly ( V-Factor starter shaft kit- replacement for HD OEM part 31477-93)
When testing it it doesn’t work correctly. (Pictures and vídeo attached)
Anyone has any ideas ?
old scoot coot
i think you are ok. on the bike(with primary case on) it is bathed in oil while cranking and when it starts the speed of the ring gear probably helps it to retract. try spraying some wd 40 on it while doing your test run.
Thank you sr
I forgot to mention it is a semi-open primary with a belt -
So, no oil in there
Sent from my iPhone using Tapatalk Pro
old scoot coot
Thank you sr
So, no oil in there
ok, thanks. thats baffeling. i guess i'm not really understanding how a harley starter works. on an automotive starter with a bendix or overrunning clutch the speed of the engine starting causes it to spin back in. i haven't had a harley starter apart. what retracts the shaft coming out of the motor is there a return spring?
Do you have the c-clip and spring inside the coupler before the pinion ? Also the long bolt should only be tightened snug, the pinion should be free to move around a bit.
Also try the bench test with a fully charged (12.8v) battery so the pullin coil has enough juice.
Careful putting your fingers near a juiced starter. Seen a guy's thumb go thru a pinion and ring gear doing exactly what you're doing !
Discussion Starter #6
Thank you all for the advice
I found out that the bushing in the inner primary was not good and it was binding the shaft ..
Replaced that one and things are smiley now
Thanks again
1 - 6 of 6 Posts
