1 - 4 of 4 Posts
I want my turn signals to be red Help with Auxiliary Running Light / Brake Light / Turn Signal Conversion Kit
2006 screamin eagle ultra classic I have been to 3 harley stores all of them tell me the plug goes under the seat but when I take off the seat I have 2 sets of wires the plug in from the harley store does not fit not even close are they selling me the wrong plug in or am i looking in the wrong place ?
STAND AND FIGHT!
I believe my plug was under the rear light cover,
especially if the widget you have is a pass-thru connection,
but that was on a LowRider.
I commend your good sense and practicality in this effort,
but I predict that like I did, you will soon opt for even more rear lighting improvement
and this run/brake/turn module will get discarded, just like mine did.
I suggest it might be more efficient in the long run, if a little more expensive up front
to go ahead and do the next step first, and you'll use a better grade of electronics
and get better technical support.
Check this post and the ones that follow it.
http://www.harley-davidsonforums.com/forums/dyna-general-discussions/21453-new-rear-fender-options.html#post319718
:ride
I'm your huckleberry
Just getting ready to answer and see ya found it. I like mine and have no reason to upgrade anymore than I have.
1 - 4 of 4 Posts
