1 - 20 of 31 Posts
Help ....! Rode bike home from work , no problems . Turned off for 20min ,
Went to ride & nothing . Have lights ,
They are showing bright . Fuel pump
Sound comes on , No turn over in engine .
Hooked up to a charger , says fully charged . Tried to jump off from a car , nothing .... No sound from starter but have lights .
Everyday vehicle ------- HELP
Alberta Strong
What model and year of bike?
Check your kill switch, New bikes will not start in gear.
Introduction before questions. Check ground wire and for power at solenoid wire. The smaller one at starter.
Discussion Starter · #5 ·
Help ,
Having the same issues ,
04 sportster roadster 1200 ,
Rode home from work , off for bout 20min , . Tried to go for a ride ,& won't turn over ,.lights comes in bright , but won't turn over , mean No sounds . Only odometer sounds & fuel pump .
This is everyday transportation HELP
Discussion Starter · #6 ·
Help!!
HELP !!!!! Bike won't start. Rode home from work .parked it for bout 20 min . Now only lights come on , battery fully charged ( rode home ) .
Won't crank and everyday vehicle
HELP
Discussion Starter · #7 ·
04 sportster roadster 1200r
have battery load tested...Mine did that, fully charged on multitester but under load test less than 10 volts...a bad cell. When trying to start would only click and sometimes a single clunk. Put in new battery and cranks like a champ.
Discussion Starter · #9 ·
Sorry peeps
Steven dean here aka PsychoSteve
I'm having trouble with my everyday & only vehicle .
04 1200R sportster Roadster .
Rode it home from work . Off of it bout 20min, tried to crank , only lights ( bright) come on .
My first bike so don't know much bout them ,but will fix myself ...
Don't know where
Problem is ,battery fully charged
Post it again.
Now posting on 3 year old thread. Doesn't matter how many times you post. You still have to fix it yourself.
Discussion Starter · #15 ·
04 sportster roadster won't fire up.
Rode home , off 20min. Went to start , only lights came on . Battery charger saying charged ....HELP
when you find out what is wrong,post it. Still haven't heard if you checked what everyone has told you.
Mississippi Cajun
He's trying to boost his post count first!
Señor Member
Dead fob battery?
Señor Member
Go to "repeat posters anonymous" and then change the battery in your fob.
does 04 sportster have fob?? don't know just asking ol lady has 08 nightster no fob? check kill switch take in and out of gear roll bike a little the make sure in neutral then let us know might also check battery for load test might have to jump start and pull battery
at auto parts if that is your only ride (when jump starting use 3rd gear will turn motor over better than first
1 - 20 of 31 Posts
