1 - 4 of 4 Posts
Has anyone know or installed the screamin eagle pro fuel injectors. I have a 57mm throttle body I like to put on but I'm here in I need to put high flow injectors. And just wondering can I put them on if my heads are ported and milled
What modifications other than porting and milling have you done? With out a large increase in size, and radical cams, the stock injectors should flow more than enough fuel.
I installed andrew tw31s cams. Ss adjustable pushrods and lifters. 95" big bore kit.
You probably already have the upgraded 25 degree H-D injectors. I doubt you need more than that. The 25* injectors have the dash 06A printed on them.
1 - 4 of 4 Posts
