1 - 2 of 2 Posts
Premium Member
The HJC RPHA-10, the top of the line model from HJC also worn by MotoGP champion, Jorge Lorenzo, is yours at $209 shipped in the lower 48 for the HJC Cage!
Get yours from Riders Discount by calling Brad at 866.931.6644 x 810 today! Is email more convenient? Send us a message through the forum or write to us at FORUM at RIDERSDISCOUNT dot COM, and we'll get back to you right away!
Available in limited quantities in both red and blue graphics, you don't want to miss out on this smoking deal.
Blue available in S, XL, and XXL
Unsure about this HJC lid? The RPHA-10 is far superior than some of the cheaper models HJC used to be known for. The RPHA-10 is an advanced composite that combines carbon fiber, fiberglass epoxy, aramid epoxy and organic fibers in a precisely aligned weave that excels in strength, energy absorption and weight savings. HJC calls this their Performance Integrated Matrix (P.I.M.) construction and it saves weight by reducing unnecessary overlap and resin build-up. The PIM shell is not only strong and light, but it is also aerodynamic and quiet thanks to extensive CAD design and wind-tunnel testing.
A hot helmet is an uncomfortable helmet, so HJC made sure that the RPHA-10 is able to keep your head cool and comfortable in warm weather. Ventilation comes from two large intakes on the top of the head, and one on the chin. All three are highly adjustable to allow for variable amounts of airflow depending on the conditions. These vents move a lot of air through the helmet without the higher noise levels that can come from some ventilation systems. Inside the shell, the full-removable/washable SilverCool liner helps wick away moisture and features a Gingko extract coating for a natural anti-bacterial guard.
$199 shipped, order yours today!
Premium Member
Discussion Starter · #2 ·
These are selling out fast! Be sure to give Brad a call on this smoking deal!
HJC RPHA-10 Cage at $199 shipped in the lower 48.
The graphics and paint quality on this helmet are very good with metallic finish and mesh paneling faded into the black.
Be sure to ask about adding an HJC dark smoke shield to your order too!
1 - 2 of 2 Posts
