1 - 10 of 10 Posts
Well, after 61,000 miles my 07 Electra Glide decided to have the cross over pipe break on my exhaust. Has anybody just patched with a weld where the cross over pipe connects and make theirs a 2-1 system? I’m limited on funds and not being able to ride is killing me. I’m pretty handy at fabrication so welding the patch on isn’t an issue.
Welding that joint does not usually last long because the metal has rusted from the inside. Without getting into large $$ you can get a "Fullsac" dual conversion. The market is full of choices though.
Look on eBay.
Reactions: slingshot383
Discussion Starter #4
Thank you! I hadn’t seen that before. I’ll be ordering this shortly. Hopefully it ships quick. I really appreciate the reply
I bought my True dual conversation on eBay a couple of years ago for less than $150.00. I installed it on my 2001 Harley Davidson Electra Glide Ultra Classic. I have the Vance & Hines Monster Round slip on and this conversion made my bike sound awesome not to mention that it runs a lot better. My bike is stage one. Haven't had any problems.
Discussion Starter #6
I ordered the Fullsac conversion on Monday and it should be here tomorrow, I can’t wait to get it put on. I’m running stock mufflers and I’ve read that they do t give the best sound. I guess if I don’t care for them I’ll just have to get another set.
The Fullsac pipe went on my '07 without problem. It was at least 10 yrs. ago, but I think you need to be attentive on how you reuse a heat shield to cover the section that the rear pipe used to join on the right. Put everything for the rear cylinder on loosely, then tighten a little here/there until it's correct.
? So ?
You went from a 2 into 1 Header configuration ...
Converted your bike into a 2 into 2 TRUE-DUAL exhaust ?
Didn't this REDUCE the HORSEPOWER instead of INCREASE it ?
Just Curious - I'm not well versed on Twin-Cam or Milwaukee-8 ENGINES
Discussion Starter #9
? So ?
My original plan was to make a 2 into 1 system, the crossover pipe broke at the weld for the left side and my thought was to just weld a patch over where the left side connected. Then a Fullsac conversion kit was suggested and after looking and reading about it I decided to go that route and go with true duals. I haven’t received the Fullsac conversions yet so I can’t say one way or the other on torque and HP gains or losses.
? So ?
You went from a 2 into 1 Header configuration ...&
Good question. I've always read/heard that a 2 into 1 system provides better low end. Before I did my Fullsac conversion, I rode my Electra Glide all around my town. I paid close attention to ease of moving from a stop and how much throttle & rpm's were needed. I did the same after putting the Fullsac on. It took a little more rpm's to smoothly start afterward. I probably would not have noticed, if I had not paid a lot of attention to the before. The mpg is identical to before, and I cannot tell any difference once underway. I do ride higher in the rpm range than many HD riders, so I can't comment on loss of low rpm roll on power. I just remembered, the main reason I went this route is to alleviate some of the right side exhaust heat which at times was uncomfortable. I have fairly quiet mufflers, but the sound from behind is more separate (of course), from the saddle, meh.
1 - 10 of 10 Posts
