1 - 15 of 15 Posts
Got a 98 Low Rider, put new bars on it, rewired eveverything right, now trying to stick the wires back into the backbone, but it's very very difficult, anybody know a easy way to do it
Squirt them up with silicone spray too get them slippery then pull from the other end.
Poser Member # 99
Could you use a Fish tape or stiff wire to pull with !!!!!!!
Silicone lube is your friend works good on Snow blowers too keep snow from Sticking as bad
Asylum Inmate
Go to home depot or lowes, or the local electrical supply house. Get wire lube. This is a lube made specifically for pulling wires through tight locations and over stuffed conduits.
While you are there ask if they have a small section of Wire pull string. Blow or suck that through and lube that sheathing up and it will slide straight through.
Harley Rider
All of those things mentioned....
I saw a guy suck the string through a 2 inch pipe with a vacuum to pull the new 4 wire breaker box lead from the meter into the house easy to do lube he wires as stated
Actually I just kept adding a nine in another forum until it took Robert for a user name. And have been using them ever since.
And you're right didn't keep her she was a slut. But damn she gave good head.??
Lost in Space
Was hoping she was more of a personal slut.
1 - 15 of 15 Posts
