1 - 8 of 8 Posts
i know that years 2000 til about 2007 touring models have 4 piston brake calipers that make the brake lever feel mushy because of sticking pistons. Can i replace with newer H-D calipers that are better ?
My 07 doesn't have a mushy feel. Cheapest and easiest way out would be to clean the pistons.
Kicking Rocks...
You could also flush the lines and put in fresh fluid. The mushy feel could be air in the lines too.
There's nothing bad about the Kelsey Hayes brake systems used on the earlier Harleys. If properly serviced the Kelsey Hayes brakes will skid any Harley to a stop. AND it's DOT 5 !
The MoCo switched to Brembo when the MoCo went to the ABS brake system. The MoCo couldn't swing a deal with Kelsey Hayes on the switch over to ABS. The Kelsey Hayes factory is less than 5 miles from the Milwaukee headquarters on Juneau Ave.
Yup. I have no problem with my 05 brakes. I've made the front tire howl on the verge of locking up before. And that was before I put the Arlen Ness big brake kit on it.
my 07 does not have ABS, but does use DOT 4 check your owners manual
1 - 8 of 8 Posts
