1 - 4 of 4 Posts
Stopped at a Speedway gas to fill up. Rode home fine, the next day it starts shutting off whenever I stopped. But it starts right up again. usually when I stop the idle drops way down and it shuts off some times though it doesn't. It's a 2000 Road King fuel injected with a screaming eagle stage 2 box. Some say fuel filter; only has just over 14K. Some say bad gas; but it runs fine under load , accelerates fine and all that. Any ideas ?:pull
Dirty IAC. Pull the air cleaner and squirt carb cleaner up into the IAC pintle hole then cycle the ignition on and off several times to get it cleared out.
The IAC is the idle air control on top of the throttle body.
Open the gas cap, turn on the ignition and see if there is fuel spraying in the tank. Just went through this with my Ultra, it was a cracked fuel pressure regulator.
1 - 4 of 4 Posts
