1 - 2 of 2 Posts
How do you remove the ignition switch an a 05 electri glide standard? I want to paint the plastic piece around it.
Old Member
Using the ignition key, turn the ignition switch to the UNLOCK position. Then turn the ignition switch to the ACCESS position. Insert a small flat-bladed screwdriver under the left side of the switch knob and depress the release button. Keep it depressed.
Push the ignition key down and turn it 60 degrees counterclockwise,then lift up and remove the switch knob.
1 - 2 of 2 Posts
