1 - 16 of 16 Posts
2006 Dyna FXDB
My bike needs a belt drive pulley for its rear wheel. The oem part is unavailable through HD. I don't want a chrome one. I hear they make squeak and chirp noises. What should I do? Any suggestions?
Here is a thought used one on Ebay $ 77 bucks
2006 Dyna FXDB
Discussion Starter · #4 ·
Mine is a 70T oem I do believe. Will that 65 t work ?
also , it says that chain conversion kit is not compatible with my 2006 HD Dyna Street Bob
Thank you very much for the suggestions, though!
2006 Dyna FXDB
Discussion Starter · #9 ·
They will squeak if belt is not adjusted right.
Aye! I bought a couple tools to help get the alignment and tension just right. Also bought a can of permatex belt conditioner to soak the belt with. I'll clean the belt well first with some dish soap and a toothbrush.
My 87 FXST uses a 70 tooth sprocket. If I put a ,65 tooth sprocket on will it increase the speed or not. Right now I'm pushing RPM,s to drive 65 or above
1 - 16 of 16 Posts
