1 - 9 of 9 Posts
That one looks nearly the same as the one I bought on eBay when I had air shocks. As long as it has the check valve in it that prevents air from flowing out when you remove the hose, you should be fine.
The road kills them. Keep it isolated (wrapped )in a rag or something .
Poser Member # 99
My Harley hand pump died and I pick up a Bell bicycle frame mounted air pump for 16 Bucks at local Wal- mart. I have been using it for 3 years now and it work pretty good.It has a built in air gauge and is pretty close to the right air pressure .
Go Figure
Shock pump should me a "zero air loss" style pump. No air pressure loss when the pump is unscrewed from the valve.
This is a must. The air chamber is so small, you can lose a lot of air almost instantly.
The Angry One
Keep on Ridin’
It will never work. It doesn't have the $40.00 Harley decal on the face. :D
(I can joke about it because I bought mine from the dealer when I was still drinking the Kool-Aid.)
That one definitely looks like one of the many cloned versions available designed to do the job. :thumbsup
1 - 9 of 9 Posts
