1 - 2 of 2 Posts
I have a 1999 1200 custom that has been sitting awhile. I tried starting it and it will only stay running with the choke out. I cleaned the carb and rebuilt it and changed the choke while I was at it since it was broke. Still the same issue. I am just going to get new jets instead of cleaning them. I believe it has stock jets, but it isn't all stock. It has a set of drag pipes on it and a high flow air cleaner. What size jets should I use?? Thanks for your help
I have a 1991 XHL1200, with an S&S Super E carb, mine had the .0265 Intermediate Jet in it. I had similar issues, ended up getting a master rebuild kit and after some minor adjustments, the bike's running great. Check the idle mixture screw, and accelerator screw settings... I used this guide, maybe it will assist you as well?
1 - 2 of 2 Posts
