1 - 3 of 3 Posts
I replaced the fuel pump in the tank on 2011 Road King. The pump was whining and I could hear it when bike was running. Before I started I noticed that gas was squirting in tank when it primed till it got up to pressure. It still does this on the line going from the pump to the filter. It starts fine and seems to run fine. It is squirting in tank while running too. Should it be doing this or does it need a new quick connect fitting or is there an o-ring in there.
It's coming from the fuel pressure regulator,normal. But double check your connections.
Thanks FritzHD!!! you were spot on, it was coming from the top of the pressure regulator. So all is good
1 - 3 of 3 Posts
