1 - 3 of 3 Posts
Well it finally happened, my 08 Rocker started leaking at the tank check valve. Luckily I saw the YouTube video about a month ago which showed how to rebuild it. Of course HD will not break this valve down in the book. You have to buy the entire assy includes the feed hose going into the tank. I found the rebuild kit on Amazon for 18.00 and the removal/install tool for 60.00
Of course this happened right before a big ride so I slapped some Permatex fuel sealant putty on it so I could keep riding until everything comes in the mail.
Don't let HD rip you off for a ten cent oring get the kit. It does stink the tool is so expensive but I'll have it for future leaks if it happens plus I can take care of my buddies if their valves start leaking.
you could have done a forum search and found that a common #13 (among several others listed)oring would replace the leaker.
1 - 3 of 3 Posts
