1 - 2 of 2 Posts
Good day All
Recently purchased a 2011 Fatboy Lo.
Test drove it and all the lights etc, worked on the display cluster. I rode it this weekend for the first time and the left indicator does not light up on the cluster. Neutral and right indicator light up normally when in use. Should i replace the cluster, or is there a fuse i can check?
You can change the LED assembly, PN# 68112-99A $7.50 MSRP US.
I believe the same fuse would control all of the LED segments.
1 - 2 of 2 Posts
