1 - 3 of 3 Posts
05 fatboy has kuryakyn run turn brake when I got it, and the front right signal will act as a run light sometimes, and will flash alternating with the left when it works. The rear flash alternating as well. Both start flashing as soon as key is on and will continue after key is off. I searched for quite a while, any help would be appreciated.
If your run/turn module is one that is enclosed in a piece of heat shrink, it may have gotten crushed under the seat or between seat and fender, etc. There's no protection for the electronics, just the heat shrink.
I would unplug the module and plug the oem harness back together. If things work right then the module is faulty.
1 - 3 of 3 Posts
