1 - 14 of 14 Posts
Pork Jockey
Daily driver? Might be a bit more challenging to park than my current truck, but I'd drive it! Haha!
Kicking Rocks...
What's that old saying about being blown. .. :think
Here's the motor running....
Try'n to behave
STAND AND FIGHT!
I've run propane in a turbo diesel, more for a cleaner burn than power, but it's still a boost
you're still limited by the amount of oxygen in the cylinder, with a hard pushing diesel
even under high boost, if it's blowing black smoke like crazy there's way more fuel than oxygen,
so since the fuel is there, but not enough air, adding nitrous could instantly stop the black smoke
and greatly boost power, because suddenly there is lots more oxygen.
In diesels you're supposed to run propane or water/methanol injection.
You can run nitrous, but not alot of it.
Sent from Motorcycle.com App
Earthbound misfit, I
Discussion Starter #13
Actually you can run as much nitrous as you want in a diesel. What it doesn't use for combustion will just go out the exhaust. It won't lean out a diesel like it will a gas engine.
Found this: good info
Diesel Nitrous or NOS systems - differences
STAND AND FIGHT!
I will warn anybody that might try propane, but my turbo Mercedes
knocks hard if it gets even a whisp of propane
without boost being up at least a little. it makes no sense to me at all,
if propane is going to pre-ignite at all, why under low load and no boost? :think
I don't think old mechanical injected Mercedes is smart enough to run advance?
I used one hobbs switch set for 2 lbs and another at 5 lbs,
I could hear them click almost at the same time.
Needs to be a very low bleed, high levels of propane will knock, I hear.
Whoosh.
1 - 14 of 14 Posts
