1 - 5 of 5 Posts
2016 Sportster 1200T superlow
My low beam and all 4 bullet running lights do not work but high beam and all blinkers are working fine as well as tail light and break light, I only have 3 fuses under side panel 40, 15 and 10 amp, all have power on both sides and continuity across fuse. Has anyone seen this before?
Check that you don't have some burnt out bulbs. The blinkers are on a different circuit and the rear lights aren't running lights, only the front are. Dual filament front bulbs and single filament in the rear. The headlight is also dual filament so the low beam filament could be burnt out.
Really need a wiring diagram to give an intelligent comment, but not having one, here goes. All of the lights not working suggests a common fault, which may be related to the ignition switch or it's wiring. All of the non working lights should illuminate when the ignition switch is switched on. There is a starting point. The hi beam, that's a fly in the ointment....
Sent from my moto g power (2021) using Tapatalk
1 - 5 of 5 Posts
