1 - 9 of 9 Posts
I have a 2013 fuel injected breakout. Last few days the engine has been idling unusually low. 800-900rpm. Yesterday while driving home on the streets the idle at lights would drop down to 500 then the engine would cutoff. Started right up three times. Fourth time I had to wait 30-seconds before it would turn over.
Any thoughts? Dealership couldn't replicate the problem but the engine had cooled by the time they got to it if that matters.
I replaced the stock filter with a heavy breather which has been on for about 8-months along with the V&H 2-1 pipes.
Land vehicle Vehicle Motorcycle Motor vehicle Automotive tire
Discussion Starter · #6 ·
Thanks for the suggestions. No codes came up. A friend suggested that the control wire that was previously connected to the stock air cleaner was resting on the motor and overheating the circuit? Wire tie should fix that but I'm not entirely sure that was the cause.
1 - 9 of 9 Posts
