If you leave it alone, you'll have a hell of a lot more acceleration than a factory 1200, it will turn over a bit faster on the highway, but not a problem. If you used Wesco pistons, and some other brands, which are lighter than factory, the vibration isn't even worse. If you want to change both the primary and secondary, the cost is pretty high, for what you get. My opinion, is leave it alone until you need new sprockets and belt, then investigate just changing the secondary. Leave the primary alone.
