U R Right....or ride faster, been riding for over 60 years and haven't fried my nuts yet.....
U R Right....or ride faster, been riding for over 60 years and haven't fried my nuts yet.....I don't know...we ride motorcycles.....heat is par for the course...deal with it or by a moped. Or put on thick jeans like Levi's.
88B (balance) will be in Soft tails. The A motors ( no balancer) are in Dynas and touring bikes. I remember when people stared complaining about heat. When Harley brought out the 96". Bigger engine, more heat. My old Evo, never a heat issue. My M8 runs cool.There are air deflectors from Harley and other aftermarket manufacturers for just that purpose. I think they are model specific, not motor specific so I guess it depends on what your 88B is set in.
When I rebuilt my engine I ceramic coated the headers, pistons, exhaust ports, valves and cylinder heads. Went from 88” to 95” with a 10 to 1 compression. It does not get as hot as it used to.I hear that my 2003 Harley Davidson 88B twin cam motor produces unbearable heat especially from the rear cylinder head. Is that true? Does anyone here have a product or solution that reduces the heat hitting the driver‘s thigh to make it more bearable?
I have had several TC (oldest was 2009) and never felt it was something I needed to fix. If you do a lot of 2-up it will be very noticeable for the passenger. Of course, if you ride in shorts, it will be a major problem. If memory serves me the primary heat source is the rear header.I hear that my 2003 Harley Davidson 88B twin cam motor produces unbearable heat especially from the rear cylinder head. Is that true? Does anyone here have a product or solution that reduces the heat hitting the driver‘s thigh to make it more bearable?
Apparently yours is not set up with the computer shutting down the rear cylinder when it gets hot sitting at a light. With that in mind i would be sure to run pure 100% synthetic oil. You can do that because your engine oil is separate from clutch so you don't have to run a para-synthetic oil. Pure offers a bit more cooler running. My suggestion would be Amsoil.I hear that my 2003 Harley Davidson 88B twin cam motor produces unbearable heat especially from the rear cylinder head. Is that true? Does anyone here have a product or solution that reduces the heat hitting the driver‘s thigh to make it more bearable?
The 2003 engine doesn't have the EITMS available onboard.Apparently yours is not set up with the computer shutting down the rear cylinder when it gets hot sitting at a light. With that in mind i would be sure to run pure 100% synthetic oil. You can do that because your engine oil is separate from clutch so you don't have to run a para-synthetic oil. Pure offers a bit more cooler running. My suggestion would be Amsoil.
