1 - 6 of 6 Posts
I recently changed the throttle cable of my street 750 for that I loosen the tank and disconnected the throttle sensor and connected everything properly now my bike is not starting please see this video video , light, horn all working but when I on the engine switch tik tik sound what I need to check? i checked all injectors everything connected
battery is fine checked showing 12.8 V.
796218
I don't know squat about the Street 750, but I do know machines. Go back over everything that you touched while replacing the cable. You obviously screwed something up. More than likely a pinched wire. Happens to everyone...
Sent from my moto g power (2021) using Tapatalk
I only loosen up the tank and the throttle sensor I reconnected it properly,can you tell me where the tik tik sounds comes from ?
So swap out that relay for another. I don't know about that model, but many relays are interchangeable. Look at the number on the relays and if they match, try changing it with another.
Again, go over the work that you did. Check all of the wiring under the fuel tank. More than likely you pinched a wire. Other than that you will need a service manual if you are capable of reading a wiring diagram, or a dealer.
1 - 6 of 6 Posts
