1 - 11 of 11 Posts
1995 softail custom 10 to 1 dome pistons Ran ok but had junk carb just put new s&s super e on and set adjustments to manufacture start specs It will not run unless I give it a lot of fuel and to keep it running u have to keep cranking the throttle fast. Sounds good during that but if ya hold throttle steady or try to let it idle it just dies. Also misting a little fuel out of carb while running but that may be normal with filter off any ideas
Super Moderator
inline fuel filter? maybe some fine tank corrosion clogging up the works? I had a very similar sumptom on my 97 heritage, also Super E. inline filter worked wonders.
Does not have filter Took carb apart once to clean jets but didn’t see anything
Discussion Starter · #4 ·
I will clean tank and put filter on just to see bikes been setting for a few years just now starting to prank with it again
There's a filter in the petcock also. Actually it's a plastic screen in the tank that accessible thru removal of petcock.
Super Moderator
i was in a heavy deployment cycle so mine sat most of 4 years. the HD shop kept screwing with the timing and tried telling me i needed all sorts of engine mods. Found an Indy that looked for 2 hours, undid the crap fixes, 2 dollar filter, ran awesome.
How is the fuel flow to the carburetor . . . If you close the petcock, remove the fuel line from the carburetor, hold the open line above a container and then open the petcock, are you getting adequate fuel flow? From what you described, it sounds like you are not getting enough fuel. Do you have a way of hooking up an external fuel tank (e.g. I have a plastic lawnmower fuel tank that I can hook up to a carburetor) and see if that makes a difference. Just some thoughts.
Reactions: WiSeNhEiMeR and JTJ
Discussion Starter · #8 ·
Thanks yea I checked that It gets fuel if I rev it high it runs good just can’t hold it steady or let it idle. Seems like once it gets below 1/4 throttle it’s like u shut the key off unless u hurry and shoot the fuel to it again
Where exactly did the NEW S&S carb come from, EBay or a dealer ? A new S&S Super E is a plug N play for an EVO. The only adjustment that would be needed is a tweak to the slow air screw and the throttle cable idle screw.
Maybe try undoing all the adjustments you made if you can still remember them.
Also if it's a BRAND NEW S&S from a dealer it's under warranty and you can contact the S&S tech department directly for help.
Discussion Starter · #10 ·
Thanks guys for the help. I figured it out intake gasket not sealing. Fires right up now Now time for the fine tuning
Flats where its at
after its all together do old school ck for air leaks = spray anything flammable near back of intake / manifold gaskets and manifold to heads clamps...[spray away from air intake] bike will rev up if there's a air leak/ bad gasket jus sayin
1 - 11 of 11 Posts
