1 - 15 of 15 Posts
I have a 1990 flhtc ultra classic.i found under the fairing , throttle side in front of fork . a little wrapped piece of what I thought to be porcelain..it has 3 wires coming off of it , 2 purple and 1 black..it was very hot to the touch ..it is cracked was just needing to know what it may be
Pic of part would be helpful
If it's tie strapped to the upper right fork leg it would be the TSM.
Kicking Rocks...
It’s a resistor.
Maybe a load balance for led lighting in turn signals etc...
Follow wires
Discussion Starter #9
Yea my friend said same thing. Thanks for the quick response brother . I wonder if it just got old and failed is why it was cracked and really hot to the touch.. I hear those aren't supposed to be. Covered with tape also?
Kicking Rocks...
They also make them with a heatsink.
On the side we can't see should have the wattage... 5.6 ohms is the resistance from the side I see...
Discussion Starter #13
On the side we can't see should have the wattage... 5.6 ohms is the resistance from the side I see... View attachment 783043
The one i found 15 w. Im guessing watts.
If it’s getting hot mt guess would be a load resistor. If it has LED bulbs installed anywhere they more than likely need it to operate properly.
Yes, to me that would indicate 15 watt... I am not sure what it is wired to and that may be the reason they are heating and cracking as the load is greater 15w.
I believe the lights r running thru it... seeming seeming as to why all of my bulbs are blown signals and low beam on my headlight but the high beam still works
Discussion Starter #14
I hooked up the resistor same way it was,but I noticed that it was gettin hot ,very hot so i killed the power. Im going to look wiringng harness overand see if I can find any wires messed up or crossed
Discussion Starter #15
Ok I looked over all the harness really good . all connections seem fine and all the breakers are good..i tested the stator then the regulator. Both checked out perfect..so now I am going to check my handle bar switches because I think the short im looking for is in one of the blinker switches
1 - 15 of 15 Posts
