1 - 5 of 5 Posts
bike will idle just fine put it in gear take off it backfires and shuts down have no fire out of coil pull all 4 fuses put them back in bike fires and runs at idle take off go bout 1/10 mile dies n no fire untill i do fuses again i know its elec. but cant find it .
What's the static battery volts across the terminals. Should be no less than 12.8v.
The only way removing and re-installing the fuses can make as difference, is if there's a bad connection on one of them. Maybe even inside the fuse itself. Hell, I'd replace all the fuses with new ones and see what happens.
1 - 5 of 5 Posts
