1 - 3 of 3 Posts
Ok so I have a 03 Sportster 1200C. Here is the issue I now have no taillight, brake light, Headlight or front running lights. The turn signals work front and rear but nothing else. Was trying to find a fuse box and as of right now do not have a manual "one is on order now" did a search for where to locate the fuses and the results said about the panel beside the battery, I pulled that and the seat off with no luck. Please help.
Thanks.
Discussion Starter #2
Problem solved!
Delusional43
The fuse block is located in the upper left rear corner of the oil tank behind the left panel under the seat. The fuses are rated at 15 Amperes. There is one large rectangular box that is the starting relay and to the right of that are two columns of fuses. The lighting fuse is the bottom fuse in the first column. It usually says what fuse is what on the inside of the left panel. The easiest way to check the fuse is to pull it out and look to see if the filament is broken. If thats not the issue shout again.
1 - 3 of 3 Posts
