Hopefully this will be the last dumb question for a while, provided I don't run into any more problems... I was able to borrow a motorcycle jack for this weekend. My jiffy stand has hung down halfway for as long as I can remember and drags on moderate to severe left turns. While I had it up repairing forks I figured I'd just replace the spring with the new one I'd purchased. I bought a new spring a few weeks ago. Easy right????
Well I have crappy luck so not for me. I have a 90 Sporty. The stand itself has a hole to slide spring through, but the frame has a peg with a nipple on end. The spring I took off had the hook end bent around that curve even though it was sprung way too much, I tried bending the new spring with the curve using vise grips but just bent more in a V instead of around the peg in a circle like the peg is shaped.
I am ready to get back on the road, tomorrow if I am lucky, and have this stupid ass problem that is more than likely an easy fix. What would ya'll suggest? Keep in mind this is a brand new spring. I bought a second spring today in case I can't get this replacement to work out.
Below I have the stand w/o a spring to show what I'm talkin about and a 2nd pic showing the springs. From right to left is the spring that came off (I had to break off) was sprung too much and hung down, the spring I tried to replace with sprung one (tighter, new unsprung spring), and unopened spring (does not at all fit curves of stock spring either).
