1 - 3 of 3 Posts
While out on a ride the other day my battery light came on (no check engine light). When I got back home the bike would not start right after shutting down, but I could get it to start after about .5hr. I haven't ridden since, but I have started the bike without issue after being on a trickle charger.
I checked the DTC codes using the odometer and it turns out the bike is throwing a few codes:
ECM y: P0562, P01632, and Pn 001118-01
BCM y: b2161, b2173 and Pn 69991-11A
SPDO y: b1210 and Pn 67439-11
Can any break down what these codes mean?
Thanks
Codes are a sticky in the electrical section.
I had similar codes and the same PN
I have a 2012 Deluxe and first had check engine lights - checked codes and then cleared them to see if they were old and would come back.
I have 15000+ miles and just started having problems after a 15K check - clutch cable needed to be replaced and now this. Ugh Battery was replaced 3/2015. Usually have it on a tender but not in the last 2 weeks after a ride. Now my battery is dead.
My extra codes were
b2121
b2166
b2272
Did you ever get an answer? what is PN 001118-01?
Thanks
Gayle
1 - 3 of 3 Posts
