I think wide glide makes it a wider rear back tire ,hence wide glide so wider frame to make rear tire fit , so wider seat pan to match , that's my guess best way to really know is measure your seat that fits , now against anything , else or if you can do a test fit the frame is part of what makes seats all different , pans that is ,Okay so I got a 1993 Harley Davison dyna wide glide I can’t find a seat for my exact year and modelbut I found one for a 1993 low rider fxdl would that fit if I made a new hole for the mounting
Wide glide refers to how wide apart the front forks are spaced (10.5" or something), has nothing to do with the back-end or frame width or rear tire. Uses the same base frame as all the other dynas.I think wide glide makes it a wider rear back tire ,hence wide glide so wider frame to make rear tire fit , so wider seat pan to match , that's my guess best way to really know is measure your seat that fits , now against anything , else or if you can do a test fit the frame is part of what makes seats all different , pans that is ,
Oh ok great everyone learned something thenWide glide refers to how wide apart the front forks are spaced (10.5" or something), has nothing to do with the back-end or frame width or rear tire. Uses the same base frame as all the other dynas.
