1 - 3 of 3 Posts
· Registered
How y'all my name is Chris and I need help with this problem I'm having I have a 1996 Sportster XLh 1200 and I'm currently in the process of redoing it I've got the motor pulled off I got the motor most of the motor apart except for the bottom end I got some parts of powder coating more or less I'm just going through redoing the whole bike well in the meantime I pulled my primary cover off, my timing cover and all that, putting new cams in it, springs, valves, valve seals, pistons, etc. Well all the oil drain out of it and in the primary cover side iv found a little bitty snap ring in the bottom of the case. Any ideas on what it could go to?
1 - 3 of 3 Posts
