Need helping replacing entire wire from left switches
942 Views 5 Replies 4 Participants Last post by  Gilbert P.
I’m trying to replace the hole wire so I want to remove it from the switch but idk how to depin these. I tried to figure it out but it’s very flimsy and I fucked it up.
2020 Lowrider S
1 - 6 of 6 Posts
What exactly are we looking at here?
What switch are you working on?
Why are you trying to replace the wire?
Note: for anyone else that doesn`t know...
Never work blind, especially on a modern electrical system.
When doing a job like this, always have the electrical diagnostics manual open.
The electrical diagnostics manual will tell you exactly how to do this job, on every connector on the motorcycle.
Reactions: 3
If bike has CAN bus with BCM a lot of stuff is permanently powered so pull the maxi fuse if you haven't already.
The connectors, type and where they are is also posted in the FSM.
This is the left handle controls switch (Part #71500292) . I removed the buttons and circuit boar to get to what you see in the pic. I had a spill in the rain and it cut some of the wires real short and would like to replace them. The bars are off the bike and disconnected. Thanks for the reply
Just bought electrical diagnostics manual. Gots some reading to do. Thanks for the reply’s
1 - 6 of 6 Posts
