Chances are, Jim, your clutch cable needs adjusting. However, your profile doesn't say what year bike, so I'm not sure if you got it new or used.
The best advice I can give is to unadjust the cable, and adjust the clutch basket, THEN adjust the cable to the right spec. I say this, because if the play is partially in your clutch basket, and you adjust the cable ONLY, the clutch may slip later, (if not sooner) and ruin your clutch.
If it's under warranty, or you had a recent service, there's too much play in the lever, per your manual.
If I understand your other question correctly, you're asking if you can shift without pulling the clutch? Yes....it's possible, but not really recommended, IMHO. Unless you unload the trans before clutchless shifting, you risk chipping teeth and causing internal trans damage.
