1 - 13 of 13 Posts
SoundMan
I'm suspecting the negative battery cable ground at the crankcase on my 2014 Sportster 1200T might be loose, but for the life of me I can't figure out how to get a wrench, socket, or anything else in that tight space to check it. Does anyone have experience with this or any suggestions. Thanks!
Harley Rider
Perhaps a small jointed socket.
Use a combination wrench. Put the open end on the nut, and a screwdriver through the box end for a handle.
3/8 drive socket with a swivel and a short extension . :thumb
I use a 1/4" ratchet with a 6" wobble end extension and a short socket, fits in there perfect. Also an extendable magnet to retrieve the nut if it falls loose. To get the nut back on the stud I slide the nut onto a thin blade screwdriver, put the screwdriver blade on the top of the stud and let the nut slide down to the stud then start the nut with finger tips.
SoundMan
Discussion Starter · #8 ·
Very good, I will give it a shot with the ratchet and wobble end extension. Thanks guys!
Wasn"t trying to be smart, but only, if you dive in and try a few different ways to accomplish the job, it becomes fairy easy to do. You had already been given several ways to do it. All of which work.
SoundMan
Discussion Starter · #12 ·
I know you weren't I was just having a laugh. I figured if I get the correct combination of tools to use it will save me the trouble of buying a bunch of stuff I don't need right now. Believe me I come to this forum because there is so much valuable info here from guys that have a ton more experience than me. Even my Harley service Dept. can't give me the answers I get here. Thanks bobf
1 - 13 of 13 Posts
