The neutral light comes on when the switch completes the circuit. The switch has constant power, when the neutral gear trips the switch the ground completes the circuit and the light comes on.
You can test the wire harness by jumping the 2 terminals at the connector. Unplug the connector from the switch first.
Jumping the connector terminals will turn the neutral light on if everything is working right.
