1 - 2 of 2 Posts
Where exactly is the neutral switch on the crankcase of a 2007 Sportster. My neutral indicator wont light up. At first I thought it was just a burned out bulb. But when I disassembled the speedo all I found was a LED board. I doubt now that's the problem. I saw on other discussions here that the neutral switch may need tightened or reseated or the switch itself may be bad. Where is it? Is it behind the plate on the crankcase? I hope not, because those allen nuts are tight as heck. Thanks, gravy.
The switch is located behind the front drive sprocket cover forward of the sprocket. A real beech to get at.
1 - 2 of 2 Posts
