1 - 6 of 6 Posts
So I loosened up my tank
To run a wire for a USB plug and now my bike starts while In gear without the clutch pulled In . Is there a plug I could have knocked loose that would cause this ? There should be a sensor to stop this from Happening
Well...that depends on the model and year of bike.
Sorry I thought I put it . It’s an 08 road king police
Is the neutral light working correctly?
If the neutral light is working properly, I would suspect the clutch safety switch in the left side switches.
I suggest you unplug the electrical connector for the left side handlebar switches, and read out the switch with an ohmmeter, the wires you want to connect to are the Black/Red wire and the Black wire.
1 - 6 of 6 Posts
