No gauges on my 09 Electric glide
1053 Views 6 Replies 7 Participants Last post by  webco2
My bike fires up just fine but all my instrument gauges are dead in the water. I checked the fuses and they are all good. Any suggestions?
1 - 7 of 7 Posts
I will say you either have a loose connection inside the fairing, or a bad fuse. Check all your fuses and relays.
When you check fuses don't just look at em. Check with a ohm meter. Had one just yesterday on my pick up that was no good but it looked perfect.
One of the things I've done on my bikes is replace the mini fuses in the fuse block with the ones that have a red LED that lights up when it blows....really helps for fast fault-finding on the road.
Harbor Freight has a set of them (I think they go from 5-30A) in a plastic box...cheap and a good mod.
And before anyone else says it..,do you have an electrical diagnostics manual? I believe the instrument fuse is a 15A in location 1C:
check the wireing as it goes arounf the neck. for chaffing. i wraped mine in a piece of inner tube to prevent schaffing. you can also use safety wire & pull the wires away from the steering neck. done this on my '09 triGlige 5 years ago .no problems. also disconnect all electrical connections & give them a big bab of de-electrical grease.
So what was the fix?
One and done. :spank:
1 - 7 of 7 Posts
