1 - 6 of 6 Posts
Checked posts and couldn't find answer. I have a 2013 SG and went to use cigarette lighter and it didn't work. Bike was running and would of thought it should have power. Checked fuse panel list and thought it would be the #2 Accessory, it's fine. Then thought it might be the #8 power outlet fuse, nothing there and nothing wired into that location to accept fuse. Am I missing something and is it labeled with something else? Owners manual was no help.
Sent from Motorcycle.com App
Put a test light on it. Harley has been known to cross the 2 wires.
Also try the lighter from your car in the bike lighter receptacle.
Rider
Don't count on just a visual inspection of those blade fuses. I've had then get a hair line break in them so that it looked ok but when I tested the fuse with a simple ohm meter it had no through connection.
1 - 6 of 6 Posts
