1 - 13 of 13 Posts
I HAVE NNO POWER TO ANYTHING DESPITE NEW BATTERY. 93 HERITAGE CLASSIC. NEED SOME HELP.
Fuse block behind the battery under a black plastic cover with 'fuses' lettered on it, check the main system relay for power (B+). That cover just pulls up off the fuse block.
Discussion Starter · #6 ·
Under the seat next to the battery.
Bought voltmeter and found problem is the ignition. Thanks for your advice.
Found problem. Bad ignition. Thanks
You mean bad ignition switch...:)
Had the same issue on my 12 Ultra. Turned out there was a short under the kill switch. A lot of times wires will wear in that area from vibration.
Discussion Starter · #12 ·
Yep. Bypassed ignition and presto power.
replaced ignition. Friend was confident after using voltmeter that it was ignition. Still no power though power is going to ignition or so VMeter indicated. Any ideas anyone?
1 - 13 of 13 Posts
