1 - 6 of 6 Posts
i have a 2008 Road King Classic started several times already this year all good somehow battery went completly dead after charging it cranks fast but now I am not getting any spark? 20 year kid says he did nothing but not sure is there an inline fuse I dont know about please help need to ride:biker:
If you are pulling and grounding a plug to check for spark, it won't work. The ECN needs to see compression. You can check with an extra plug. Can you hear the fuel pump priming?
The only fuse that would affect spark would be the ignition fuse. Do what the Breeze3at suggested. A real spark tester connected in series with the plugs would work the best.
What tells the ECM there is compression ?
ION sense. It measures the resistance of the compressed fuel air mixture in the cylinders through the spark plug. Its the 4th wire to the ignition coil on the EFI bikes. Carb bikes don't have that 4th wire.
1 - 6 of 6 Posts
