Nutral light not working
1804 Views 5 Replies 5 Participants Last post by  FritzHD
Started bike and runs good however neutral light not working and engine making a wining noise most of the time. Headlight gets a little brighter with higher RPM. Is this bottom end wining noise why light is not working?:feedback:
1 - 6 of 6 Posts
Guess Ill start this ... Nice Intro??.. Make Model and Year might get you some help?
Make and model would help, but basically pull the wire from the neutral switch and ground it. If the light comes on the switch is bad. Of course, make sure the bulb is good first.
Have not had time to do anything, working two jobs. At work now but just wondering do you think that wining noise be causing the neutral to not switch on?
Depends. Does it go into neutral. In other words, is the problem with the indicator only, or does your bike fail to achieve neutral altogether?
Sent from Motorcycle.com App
No. Whining is probably primary chain. Neutral light not working on a shovel, wiring, bulb, switch or bulb socket.
1 - 6 of 6 Posts
