Maxi-fuse holder? Loose, corroded terminals in the holder itself?
And she still looks great.Why would you suspect that little guy? It's only 18 years old!
That's the first thing I checked. I slammed it back and forth several times. The parking lot cameras might be entertaining to go back and watch. I might get sent to anger management for it.Remember the wiring on your old bike ? Try swinging the forks back and forth to see if anything electrical happens.
I cleaned that really well and added lightbulb grease to the connections last time.On my 99 inside fairing brake side there is a relay/ connection from the main harness to the dash... I have had the power wire come loose there a couple of times twice leaving a stop light. Just another thing to check if your year has that.
It's mounted on the fairing bracket near speaker.
Just a thought.
Old circuit breaker. Canister was brown like it had been under a lot of heat. That's headlight grease I put on there about 3 years ago.
Time will tell. I had the issue twice about 3 months apart.
It might be my imagination but it seemed to be charging a little higher.
If those are true circuit breakers, then do they reset when cooled? Is it possible the radio came on when you were no where near the bike because the breaker reset? Maybe the inrush of current tripped it when the ignition switch was turned on and then it cooled after a given time and reset.
