1 - 6 of 6 Posts
Asylum Inmate
Have you tried Xieds yet? I put the on the softtail and was able to skip the oil cooler. They make it run a little rich cool the thing down.
Poser Member # 99
Cant recommend if we don't know what you have
Climate has a lot to do with it
Do search in the forum section top of the page it's like oil which to use has been done to Death
Asylum Inmate
wondering if that would have an effect on the o2 sensor
That is what they do. They make the O2 sensor run in a slightly richer band by adding a fixed resistance in series with the O2 sensor.
Oh course you can just have a tuner rich up the mixture if Guam has a decent tuner tech.
Point is, it is not always the need to shed heat. Sometimes it is better to not generate the heat.
1 - 6 of 6 Posts
